Rear fresh air blower runs all the time
mr_waxdope_noodle
Brighton
T5 SE 174
Hi All,
I've noticed that the rear air blower doesn't switch off when I turn the engine off, it keeps blowing. I connected an OBD device to read error codes and this is what it showed (please see the screenshot for more details) - "Rear fresh air blower activation: electrical error" & "Air quality sensor: faulty". I removed the fuse from the fuse box as a temporary solution to switch it off.
I replaced the main battery recently, could this be connected somehow?
Any idea what this could be? Where should I look? Any help would be much appreciated!
Thanks,
Jev
If an Ocean 6.1 it may be stuck button, happened to ours and unit was changed under warranty.
Same. We could prise it back out with a blade but would get stuck each time when pressed. Now been fixed with replacement a/c panel :)
California SE 5.1 - all buttons seem to be OK, no one was using them recently tbh.
joeb1230
R
kernnowkarmann
Corradobrit
Corradobrit
