G
GwynF
- Messages
- 14
- Vehicle
- T5 SE 140
It's worth a try...If VW can't find an approved repair shop in the UK for the roof corrosion ask them to fund you to take it to Germany for the repair, make a nice Summer holiday
VW changed the sealant spec in 2019 see note from Claridges below when I had mine repaired again in 2020, been good since then ...Yes Claridges did ours and thus far have been pleased with it. It does appear to be the sealant that's breaking down. Thanks for this.
Just when you see some of the photos. I would be tempted to take it to a proper bodyshop and pay for it myself but at least actually have it fixed. It depends what is the actual problem, original aluminium cap or bodged plastic thing. Knowing next time they will walk away do you want them to do another VW bodge?Well, there is that.
Ours is dark metallic blue .........Just when you see some of the photos. I would be tempted to take it to a proper bodyshop and pay for it myself but at least actually have it fixed. It depends what is the actual problem, original aluminium cap or bodged plastic thing. Knowing next time they will walk away do you want them to do another VW bodge?
I don't speak from experience - my 2008 van has a bit of bubbling but you have to get up close to see it and certainly not structural or leaking - I'm just used to seeing terrible photos and terrible VW service on this forum. Not sure why I'm lucky. I have kept it clean for 15 years and I have a pet theory that light colours fair better.
Thanks for thisVW changed the sealant spec in 2019 see note from Claridges below when I had mine repaired again in 2020, been good since then ...
Claridges response -" I am guessing this initial repair was carried out some time back as this problem is normally due to the sealer and bonding that was used. VW did change these around November 2019 so if your repair was before this then this would be what has caused your leak. "
Hope Claridges can still repair yours.
Doesn’t matter if it is wrapped or painted. The bubbling would have to be rubbed down , primed etc; before it could be wrapped. Also , for aesthetics I presume you would want to colour match so you could end up wrapping the whole roof. Much easier for an expert to match the paint colour , even old paint that might have faded.Anyone have any thoughts on going down the "Wrap" route instead of paint route with the front cowl?
You could paint and then wrap it with clear wrap.Doesn’t matter if it is wrapped or painted. The bubbling would have to be rubbed down , primed etc; before it could be wrapped. Also , for aesthetics I presume you would want to colour match so you could end up wrapping the whole roof. Much easier for an expert to match the paint colour , even old paint that might have faded.
What would you guess a ball park price for cowl rub down and repaint whilst in place might be?....and a price for taking it off and having it done...I think LLLParts supply a new cowl (Primed) £137Doesn’t matter if it is wrapped or painted. The bubbling would have to be rubbed down , primed etc; before it could be wrapped. Also , for aesthetics I presume you would want to colour match so you could end up wrapping the whole roof. Much easier for an expert to match the paint colour , even old paint that might have faded.
A member in Scotland paid about £450 by a body firm specialist with aluminium body panels. Older Land Rovers suffer the same problemWhat would you guess a ball park price for cowl rub down and repaint whilst in place might be?....and a price for taking it off and having it done...I think LLLParts supply a new cowl (Primed) £137
I presume that was whilst it was still on the van.....Hard question I know ..but what would you consider too high a price...£600......£700?A member in Scotland paid about £450 by a body firm specialist with aluminium body panels. Older Land Rovers suffer the same problem
Personally under £750 no brainer if I was keeping the vehicle.I presume that was whilst it was still on the van.....Hard question I know ..but what would you consider too high a price...£600......£700?
Don’t think it really matters when. No rush. I would look for a Bodyshop that has a good reputation, undertakes restoration repairs/resprays and knows about galvanic corrosion on aluminium body panels, not your high volume insurance accident repairs.And would you get that done now before the winter, or let it run and do it in spring so it's looking it's best in the summer season?
Sounds like VW’s plastic stick on cowl to cover up the corrosion. The original cowl extends more than halfway down the sides of the roof to strengthen the roof after cutting the hole for the pop top. Expensive, which is why VW stopped doing the repair, and now just cuts out the corroded surface near the windshield and glues a plastic cover on top to cover up the rest.LLLParts can supply a VW original part primed roof cowl for about £140.
Are there any pictures on this site(or anywhere else) of what it looks like behind the headlining at the front to access the bolt which secures the cowl? Is this replacement panel a route worth going dow...obviously it means not having to sand down the original.
Is this the part we call the cowl?Sounds like VW’s plastic stick on cowl to cover up the corrosion. The original cowl extends more than halfway down the sides of the roof to strengthen the roof after cutting the hole for the pop top. Expensive, which is why VW stopped doing the repair, and now just cuts out the corroded surface near the windshield and glues a plastic cover on top to cover up the rest.
Do you want to post some pictures of it. Just so we can see what’s wrong?Thank you for posting a reply. Obviously I won't be taking that part of my van out...ever.
Must admit I'm struggling to find a trusted (or otherwise) body shop interested in sanding it down and painting it.
What does your roof seal look like , presumably rusty in the recess tgat grips the roof ?
