DonGraham
Hi, I wonder if someone with solar fitted could take a pic of their Votronic Solar Regulator showing the LED's lit when in reasonable sunshine.
The only LED that appears on my regulator is flashing MPP, which you should get at night when there's no sunshine.
It has been in at VW and they say that the solar is working, which it seems to be. Without being connected to the mains or engine running, the leisure battery will recharge to 100%, but on the regulator itself there is no indication of charging or that the battery is full, just continuous flashing MPP. So although it is charging, I am not convinced it is charging correctly, or at its full potential.
Also, I fitted a Votronic bluetooth monitor, and since fitting I have never seen an indication of charging, it shows the voltage and "Standby", see pic.
I am trying to book it in again and would like evidence of what the regulator led's should look like when working properly. The fault seems to be within the regulator and I have tried the red switch reset and regulator fuse in/out, without any effect.
Any help appreciated!
Thanks Don
Thanks Don
