dspuk
Dave
There will be a service bulletin that for any warranty claim to be approved on the bellow where there is pulling a glue remedy has to be tried first. Unless the garage does this then VW is unlikely to approve the larger claim.MyT6.1 Ocean went in for it's 2yr service today - with a hand full of things to fix.
One issue being the Pop top roof bellows (pulled away in 2 corners & repeatedly does so after poking the rubber sil back into the groove).
My local VW service centre said they have to try glueing before they are willing to replace the bellows - feels a little like i'm being fobbed off?
Also the roof sags when left open (over night). It does however go fully up when I ask it to via the control panel. VW said this is normal - and after a set time, the van will raise the roof automatically - has anyone else had this experience?
There is a lot of chatter around how normal it is for the sag. Ours does, about 1", after 3 days. Others are worse. It's to do with the quality of the seals on the hydralic rams. Over time some sag as the pressure "leaks". Some have managed to get it fixed with lots of complaining and new rams, others have done themselves, others have your explanation. Always felt to me the automatic roof raising was a bit of a software after the fact fix for a downstream issue not properly resolved. So far not been bad enough for me to complain.
