Pegsinho
I was watching the California Chris video about the water systems in the 6.1 and he was suggesting that you know when it's full because water will overflow back out of the filler (he certainly didn't give any sort of warning not to do so).
I can't believe, given there is no gauge on the outside, that there should be any leaks internally from overfilling so I assume there must be some sort of issue with these ones mentioned above. Slightly concerning if that's not the case!
