			Little owl1963
		New installation just will not connect to my Samsung galaxy A34 Phone , will not recognise it at all .
Any ideas ??
			Any ideas ??
			Are you using the phone or the app to connect.New installation just will not connect to my Samsung galaxy A34 Phone , will not recognise it at all .
Any ideas ??
			Seems others have the same problem. Need to contact Victron.Yes can't get that far at all , just won't pick up anything at all.
Get far as victron connect app on phone , that's it dead end full stop .
Bluetooth connected , restarted phone , re installed app , tried every trick in book.
Just standstill
			Solar - Output from panel directly.Also can anyone explain how the above chart works ?
			That's not usage that's the trickle charge from solar to battery.Any idea why battery column shows 1 amp with nothing at all switched on ??
Should this not be zero ?? Until switch something on ?
			Ah. The Battery column shows 2 things ?
Power from charger into battery ??
That seems lot the charger uses 1 amp from victron charger to battery , when nothing on ??
Also if switch something on , also shows what's being used e.g the fridge .
Just read in manual that power from victron charger shown as plus sign ??
Power out to appliances shown as minus / negative sign .
Can't see any those on the screen, I will further look through settings
			You may wish to consider adding a Victron SmartShunt to your setup. An example of mine is below. Firstly, I use a LOT of power as I work from my van 5 days a week so my usage is not typical for most with a Cali. But you can easily see the average discharge per day and other metrics with a SmartShunt. I have 200Ah of capacity and draw down about 90-100Ah per day on average.If amp usage cannot be monitored on the victron an is irrelevant.
And the volts are more important , what is best way to calculate volts needed for a 24 hr period ?
How many volts would a fridge need approx??
How many volts for lights per hour ??
How many volts heater per hour ??
If no these figures then can work out how many volts needed a day ?
