G
Glenhyrst
I would appreciate comments from the electrical wizards about the arrangements detailed below in my 6 months old Club Joker which runs counter to my expectations, but my knowledge on such matters is not advanced.
The cab 12v outlet bypasses the 12v main switch but is actually powered by the leisure batteries and not, as I expected, the starter battery.
The 12 volt socket in the back of the van is indeed isolated by the 12v main switch.
I know because, given that the starter battery voltage drops fairly quickly, rather than running an EHU and a separate cable to a charger to the starter battery, which as I have already determined, is not charged on EHU, I bought a plug which goes into the 12v cab socket and not only gives an indication of the battery state but through which I could charge the battery using a charger plugged into a 13amp socket in the van whilst on EHU.
For the reason obvious from the above, it did not charge the starter battery.
Furthermore, on a separate but related issue, the tracker software gives a voltage readout which surprisingly is the voltage of the leisure and not the starter battery.
