Only leave vehicle in position P - T6.1
  • Thread starter Cali_MattHousley
  • Start date
Cali_MattHousley
Cali_MattHousley
Loughborough
T6.1 Ocean 204 4 motion
Hi,
I've started getting this message "Only leave vehicle in position P" when selecting Drive after first starting the Cali (2 days after my Warranty expired!)
I believe it's to do with a faulty Microswitch in the gear selector. I've found a "fix kit" from VW 5Q0713128A, but my 'gear stick enclosure' seems to be slightly different and is missing the Torx screw to bolt it in place.
Does anyone know if VW make a fix kit for my style of 'gear stick enclosure'; or even if this fix kit will work on mine?
Hi,
Take it back to vw they should do good will or pay 50%
The VW repair for T6.1 seems to be to replace the entire gear selector - fine if you can get it done under warrantee, but a rather expensive repair for a very minor fault. As far as I can tell, there is no performance or other problem with this fault - just a rather annoying error message. If you can live with it, definitely the cheaper option is to ignore it. I started getting this message (intermittently) about a month ago - 1 week into a 4 month trip!! So far no problems, so I’m living with it for now, but will get it sorted when I get back home after Easter.
Make sure you test it before you drive off and get home 45 minutes later, then find Reverse is an absolutely pig to get into.
Try D to R and make sure it slots in nice.
Mine was replaced 4 weeks ago and Reverse is a pig. Back in, in 3 weeks.
I’ve now had this fault on the van for over three months - will take it into the dealer when I get back home after an extended winter trip. However, it has now developed a very annoying feature. Randomly, when parked up, a warning message appears on the dashboard, accompanied by either one or two pings. It may happen a few minutes apart, or sometimes goes for hours without it happening. Also happens whenever a door is opened. This goes on all night! Anyone know how I can stop this, as it is keeping us awake!
My appointment at VW finally came round for them to diagnose the issue. But it didn't happen for them... So they're not willing to fix the issue. It's still doing it though. When I've got the time I think I'll take the gear leaver apart and replace the microswitch myself...
Finally got home after our extended winter trip. Took to the dealer, who ‘replaced an electronic circuit under the gear selector’. Not really sure what this means, but it is now fixed, under warranty so no paperwork to provide more detail. Not sure this really helps anyone, but it’s all the info I have.
Get yourself signed up for the All-in warranty - can't see that they could exclude this fault if it's not doing it for them.
Warranty not an option apparently. Also said, the fault has to be diagnosed during the warranty period (I haggled the wait time down from 9 months to 3...). So the fact I reported it during my warranty period doesn't matter....
Clearly you have a better dealer near you than I do!
Well done, glad you got yours sorted. :)
if you join the all in warranty now you will be covered if it fails in the next two years - they cannot say it was an existing fault as they've now checked the van & couldn't replicate the problem.
The warranty is effectivly free if you would pay for the servicing anyway.
This is the All in Warranty + Service Plan as mentioned by @andyinluton
Hi all,
I also started receiving the same error but my cali is out of warranty. Anyway I got the part number that needs replacing (for me - 7LA 713 025 G) from the dealer/service shop.
Does anyone know if this is a simple replacement (old housing out -> new housing in) OR is there any software related tweaks that need to be performed?
I don’t know if this will help anyone but I had the same fault. I was able to remove the gear mechanism and replace the physical switch. It’s doable for a DIY. Took me about 3 hours. You have to remove some of dash trims and glovebox, the gear knob and cover. Once that’s all off, you can remove the gear mechanism, open it up and solder a new switch in. 7c26f5b0-2f6d-4195-8bc9-d1489e9ce2bd.jpeg
Hi @DaveGwood where did you get the switch from please and do you have a part no? as I seem to have the same problem. Many thanks
No sé si esto le sirva a alguien, pero tuve el mismo problema. Pude quitar el mecanismo de cambios y reemplazar el interruptor físico. Es posible hacerlo uno mismo. Me llevó unas 3 horas. Hay que quitar algunas molduras del tablero y la guantera, la perilla de cambios y la tapa. Una vez quitado todo eso, se puede quitar el mecanismo de cambios, abrirlo y soldar un interruptor nuevo.View attachment 142253
Gracias a esta publicación logré reparar mi unidad. Dejo la foto con el código del micro interruptor por alguien lo necesitara.
Perdón por no publicar en inglés.
