jonclareVWGrand
We’re absolutely loving our new GC680. Just a few issues we need help with
- wifi router
-Water gauge
- wifi router
- its not happy. I‘ve pulled the plastic cover off the rear side of the drivers seat and moved the connector from the wrong middle socket into the outside purple socket - that means the router gets some signal
- but it still gets less than my iphone. Either the Lesswire router has a fault, or the aerial has a problem
- I’ve spent hours on this forum and calibord.de, and can‘t find a solution
- I can get 2G / 1Mbps when my iphone is on 10Mbps, and 8Mbps when my iphone is on 45Mbps (same SIM - switching between the router and my iphone)
- either the router has a problem (VW warranty) or the aerial is an issue
- I’ve seen the photo below on the german forum - does anyone know how to remove the white panel above the door to see if there is a wiring problem with the aerial? Its the square box with the purple connector and I’m wondering if the connection is a bit loose. I strongly suspect not but that will avoid a trip to the dealers if I can fix it. It seems fairly well fixed to the wall, so I’m not sure where to pull / unscrew to take it off?
-Water gauge
- despite using over half a tank of water, it still shows 100%. Not sure where the sensor is? The waste water gauge seems OK, so we are using that to judge what is in the clean water tank - if the waste is 20% full we’re guessing the clean water is 80% full
- where is the gauge located and is there a way to unstick it?
- there was another post on one of the forums that says maybe emptying and refilling a few times gets it working? After the 3rd refill we’re on 15% waste and 100% fresh.
- Water tank overfill- this is probably the main problem. When I fill the fresh water tank and excess water comes out of the external filler pipe, water comes out of the air vent on top of the water tank under the bed. The filler inlet valve is higher than the air vent on top of the tank so that is always going to happen. I’m wondering if there is a vent pipe missing?
- on the photo below the blue vent pipe circled in red firstly fills up the circular recess in the top of the tank, and then it pees water out of the vent and down the side of the tank. First time I did this it came out of the bottom of the rear doors at the back of the van, this afternoon it ran from the tank towards the passenger seat
- any ideas? Am I missing a vertical pipe to increase the height of the air vent valve to make it higher than the input filler? Or do I just need to be more careful and only fill to near the top? Difficult to do with a level meter that shows a c. 30% full tank as being 90% full
If anyone else has had similar problems, please let me know. I’d much rather self-fix than take to a dealer.
