Wind deflectors
Got my genuine VW wind deflectors from the Dealers on the day I picked up my Ocean last month.....cost less than £38. Ok, still to peel off the sticky tape (no screws needed) as it's been too wet or windy to fit them yet but I can't see that they'll pose a problem, and being externally fitted they'll not be a problem for acoustic door glass.
For what it's worth, I've also, today, purchased a genuine VW rear bumper top protector for under £66, so that's another warm, dry still day's project (more sticky tape).
Hi Marco. This link may be helpful for fitting the deflectors:
Thanks, I watched it a day before deciding to buy it.....but thanks for drawing it to everyone's notice......you learn so much on YouTube
Climairs don't use clips. The glass doesn't come into contact with anything sharp or metallic so should work just fine. And by btw its not required to screw into the plastic mirror trim..
Hi
I've just bought and fitted these but have held off drilling and fitting the screw. Have yours been fine without using the screw?
Hi
No issues whatsover. I used padded double sided 3M tape and can confirm the adhesive is still holding well over a year since they were installed.
We had Hekos and have since gone for ClimAirs.
Linky for ease of finding the right ones : https:///3J3REDz
Hekos are held in with clips only - not a problem, until they are. Ours lasted fine for 18 months and we recommended them everywhere we went. Then one day, wound down the window and one fell out, briefly scratching the door as it fell.
We went for ClimAirs in January and haven’t looked back.
The design is a little more shapely, darker and a more natural grey/black tint; Hekos are a redder tint. The ClimAirs also feel significantly thicker.
As an aside, if you have an acoustic pack, you CANT use Hekos due to the thicker glass. You’ll chip the glass during use as the clips are too narrow.
Only downside of the ClimAirs is a TINY screw which holds them in place - but something we’re comfortable with given the security and peace of mind.
Do Amazon just do them in a black? Do they do a light smoke ..what do people tend to go for ? Any photos attached to a Cali please?
What side tape did you use?
Been following this and decided on a set of Auto Clover wind deflectors, stick on, easy to fit, nice quality. Only £31.99 incl postage from Amazon
Just fitted climair, i do have the acoustic pack no problem with window also used the grub screw looks fine and solid!
Do you have a photo — I think some have used a bit of tape instead of grub screw?
Just fitted the ClimAir ones in black to the Cali. They no longer come with a grub screw but a clip that attaches to the trim.
Only just installed so no data to review on their use but will report back after our trip in March!
Nice I love my Climairs. Easy to install and the profile suits the cab shape. Would love to see a pic of the clip design. I used double sided tape to avoid drilling into the trim. Secure enough but maybe the clips are a better alternative.
Any reason not to go with the OEM VW model for these? Available on ebay for £25.
