How low can you discharge leisure battery
T
Tony L
Haslemere
Grand California 600
Hello, how low can you safely discharge the leisure battery according to the control panel? Eg is it not below 50%?
Thanks Tony
Thanks Tony
As a general rule I wouldn’t take it much below 50% as if you do drop it lower on a regular basis it can damage the battery life.
The panel allows it to discharge down to 20% before it shuts down the consumers. Battery life is a function of depth of discharge and number of cycles, you get fewer cycles the deeper you discharge. Over discharging ,<10%, can permanently damage the battery. A bit more info on that attached.
  • MM001- Battery Banter.pdf
I
IsThisNameLongEnough
I
H
5K
Andy
Kris Emery
12K
fili villanueva
fili villanueva
