Lithium plug and play battery
julien_christian
grenoble france
T5 SE 140
Hi,
my dealer make a proposal for battery replacement. Instead of AGM, he recommand Lithium "plug and play" battery, like EZA EAZ 100Ah.
It seems to be totally plug and play for Calif', without DC charger or other conversion parts.
Did you ever try this solution ?
Best regards
EZA EAZ 100Ah
Specifications said:
Parallel assembly: No
Your SE would normally have two leisure batteries in parallel. With the split charge relay closed your lithium battery (or batteries) will also be in parallel with your starter battery.
For me the risks of it not working properly and the potential time wasted going back and forth to the dealer are not worth it.
The manufacturer's website also does not instill confidence (it refuses to connect from my location).
JMStockholm
JMStockholm
P
Nand0
Nand0
bob1651
13K
