John Iddles
The silver rear blind on the hatch's double glazed window was stuck in its fully extended position (ie would not retract). Initially it had deployed OK but was soaking wet and looked like it had been for some time as there were signs of corrosion along the aluminium handle strip. Then when we tried to encourage the blind to retract by gentle tugging upwards, the silvered material completely came away from its (hidden) roller inside the plastic hatch liner. How do I access the blind mechanism so we can fix this? I will also want to investigate why the blind was so wet and corroded. TIA
