Closing the Roof
Do you check externally when closing the roof?
  • I always check externally with the roof 3/4 of the way closed before fully closing
    Votes: 26 45.6%
  • I trust the mechanisms and only look upwards internally to make sure the bellows are folding in
    Votes: 29 50.9%
  • It depends on my mood
    Votes: 2 3.5%
  • Total voters
    57
JuanVecino2023
JuanVecino2023
Minchinhampton
T6.1 Ocean 150
Having rented Californias previously which had bungees around the bellows and coming from the antiquated manual pop tops of Splits/Bays, I thought I would solicit advice from owners as I now own an Ocean.
Do you check externally every time you close the roof?
Do you trust in the system?
I am not one to drive home to check I turned the iron off, by way of a glimmer into my mindset.
That said, I’d rather avoid an expensive day at the dealer.
To protect the innocent, I have chosen not to display results publicly.
Used to ask my wife to check on the outside while I was checking on the inside and operation the control panel, but after a while the outside check seemed useless. Have been checking only from inside for quite a few years now without any problems. Must say we do have a bellows bungee in place. Only when it'd really windy I might consider asking her to look from the outside.
I start by checking nothing is on the bed, then stand up between the front seats to start the closing process whilst checking the folding internally, then when almost closed I sit down, arrange the front panel so it folds neatly and finish the close. Always done with one downwind facing door open. Then I have a quick walk around outside to check the roof is sat properly all sides.
I stick my head inside and look. I can visually see if all the sides are coming in - that's good enough for me. If it's very gusty, I sometimes get my wife to check for me as it comes down. I think the 6.1 bellows have more supportive braces though that force the folding a bit more than the old ones. No bungee here.
This. And dont forget to close any windows/mesh.
On the T5/6 the Control Panel stops on the way down and asks you to check before completing the lowering of the roof. Does that for a reason. Don't know if the T6.1 does that.
It does flash up a warning.
This was my instinct - the structure seems quite rigid. It seems like it would need a healthy gust to stop them folding in correctly.
I haven’t bothered ordering a bungee, as I read it can compromise any claims for roof defects. No idea if this is the case or otherwise, but if they aren’t needed, I shall leave them.
We used the bungee, but had an internal isotop fitted as you couldn't see the vans canvas folding from the inside when closing, as it was obscured by the isotop. Seemed like a good investment given the low cost.
Btw is it ok that both sides of the roof going down with the different speed? Right side is lower than left one, but roof closes well though.
I have an Isotop fitted as well so its harder to see the canvas coming in, so always had the bungee fitted as well. Even with this occasionally the canvas will almost get trapped so I always pop the canvas in from inside, and then walk around and check from outside when almost closed.
I have an old T5 2006 ish canvas though, and am going to be replacing with new bellows in a couple of months once im sure the new ones dont leak any more.
I have been considering the remote control for the roof from Kernow Conversions, as seen here -
So then I can watch from outside and control the roof at the same time, but £450 and a long drive to Cornwall and back.
On the topic of opening/closing, anyone else find sometimes when opening/closing it stops and wants you to press the button again? I don't mean the usual pause on the way down to check everything is clear, it's more like an intermittent fault type issue?
