OllieCollieCali
Yes I think its either the right angle drill, or lift the bench out job.Thats annoying..! You'll need a right angle chuck/drill to get in there I guess.
Worth checking some of the other threads on here re: fitting the drawer to T5s. There may be an answer...
I have found this post, which could prove very useful! https://vwcaliforniaclub.com/threads/guide-fitting-the-small-under-bench-drawer.1768/post-72293
Although the runners are on different brackets, so im not sure if these measurements will still be accurate for the drawer runners you used if I used your runners to then mark the holes. But I assume they wouldnt be too far out.
