Jubilado Tim
I want to replace my Varta AGM 7PO 915 195 starter battery with the identical Varta battery and ref no. The AA advise that there's no need to recode if the replacement is identical. What views do members have on that?
I didn’t recode my new battery - but I did take it for 20 min spin to get rid of the mini beeps, whirring, etc. All fine then.I want to replace my Varta AGM 7PO 915 195 starter battery with the identical Varta battery and ref no. The AA advise that there's no need to recode if the replacement is identical. What views do members have on that?
Firstly, do you have Stop/Start and Bluemotion regenerative Braking? If No, then no need to code in new battery.I want to replace my Varta AGM 7PO 915 195 starter battery with the identical Varta battery and ref no. The AA advise that there's no need to recode if the replacement is identical. What views do members have on that?
Carista, OBDeleven or VCDS software will do it, OR just drive it.Hi, just picked up a new battery for my 2016 start/stop bluemotion beach, I’ve just read the above comments regarding coding ?
Is that something I can do or does it need to be done with some sort of reader or programmer ?
Cheers
I wish we could!!Thanks for the information,
Can we not go back to simpler times when coding and the likes were not required![]()
You’ll have to convince the Environmental lobby I’m afraid.Thanks for the information,
