Sorry Now Sold Sold
Ch1pbutty
Ch1pbutty
Burgess Hill
T5 Cali on order
Sterling Auxiliary Battery Charger 3 Amp, £60
Brand new.
(RRP £ 105)
Allows main battery charging off leisure battery - ideal if you have solar panels with victron controller, as will automatically trickle charge engine battery once leisure battery is full.
The battery charger/maintainer enables an extra battery bank to be kept 'topped up' from the main battery bank which has the charging device(s) connected to it (e.g. alternator, battery charger, solar cell/wind turbine etc.) The battery charger/maintainer works by detecting when the main battery bank reaches 13.3V and allows the excess power to be transferred to the extra battery bank with only a minor voltage drop of 0.2V. This allows the extra battery bank to be 'maintained' by charging it with several amps. This device is not a high charging device, it's a maintenance device.
Voltage [Filter]12V DC
BrandSterling Power
Voltage12V DC
Height40mm
Width140mm
Depth45mm (1.8")
Weight0.25kg
Charge Current3amp
