Do your blinds stick?
chockswahay
chockswahay
Kernow
T6.1 Coast 150
I have been meaning to ask for a while now. The roller Blinds for all the side windows need careful handling and encouragement to wind back up properly and without creases. We tend to hold them lightly and centrally in the middle of the window and then ‘jiggle’ the blind gently upwards :eek:
Does anyone have a better way of dealing with this? Is there a reliable mess free lubricant? What do you do? Or am I the only one with these issues? :D
On T6 yes on the front cab ones but not on the side rear although do treat with care'
Kitchen blind on my 2015 sticks when it gets warm and then refuses to retract properly. Took some trim off to see how hard it was to fix then decided just to get some stick on insulated covers for the side windows…they keep the van warmer too!
If you lubricate then they may not stay down or in any intermediate position.
Same issue in my brand new van, following to see if anyone has any ideas. Had thought of spraying some silicon spray in the sides but not sure that would even help, feels like the traction springs are not really strong enough to me
The larger ones at the side need careful encouragement to retract, especially the sliding door and above the kitchen unit. The rear is the easiest. Completely given up on the fronts in the A pillars. What a nightmare they are to rehouse without creases or messing up the positioning of the rods.
Do not lubricate ! They move up easily- BUT don’t stay down easily !
We had issues with the door blind. The VW tech managed to adjust the door pillar trim, and this was successful to a degree, but it still snagged a little when closing. So, I sprayed just a little PTFE lube into the channel that carries the blind cable. The results were that the blind came dow smoothly without snagging - hooray! But when closing the side door with the blind closed when parked up, the blind went up half way in its own. When inside the van, closing the blind needs a couple of goes. That was in November 2022. It’s pretty much the same today! Slightly less of a problem- but we’re still waiting for the lube to wear out.
So lubricate the blinds at your peril :(
My rear blind failed, so purchased a replacement,3 hours to replace…30mins of which was a trip to screwfix to buy a rivet gun…as the blind is riveted to the boot trim with approx 16 rivets. Reckon I could do one in an hour now…good learning experience!
I’m beginning to think that there is a little bit of ‘form over function’ here :eek: Classic VW:D
I lubricated my blinds and they stopped staying down. The dealer replaced them under warranty. Was long job, taking out all the panels, etc. the new blinds are smooth but one doesn’t stay down without a little wedge.
We also suffered from sticky blinds, solution for us was one tiny squirt of thetford loo lubricant, & I mean tiny, in lower part of runner, then work up & down a few times, now runs a smooth as silk.
I just degreased the steel wire with isopropyl and that seems to fix it.
I regularly degrease ours and this works fine for a period of time - about a week or two, then they start moving up again. Over time, they stay down for longer so we might be gradually getting rid of the tiny bit of lube I used. I’ve used a couple of products but not isopropyl yet, so might give it a try. I can’t bear the thought of a dealer stripping out all the panels - you know something will rattle afterwards!
