Ichidon
Hi Eveyone,
Hopefully i am in the right forum section, apologies if not.
To start i would say i am very happy to now be apart of this forum and think i should have joined a long time ago.. As of this time last year I am/was the proud owner of a VW California T5 from 2006 (7HMA). 128KW / 174PS
A diesel 2.5 ltr DTI motor with 169000 kms on the clock.
I baught this bus at a relatively good price but now after going through 4 different mechanics and spending over 10000 euro, the bus is still not fixed and nobody can seem to help.
Of course if I go to another mechanic, they would have another idea but it seems like i am paying constantly for people to guess and not getting any results.
At the begining of my problem the bus blew white smoke, the Emmisions warning light came on. I took it to garage and it was really since then i have had this problem.
He took out the partical filter and had it cleaned. He also adviced me to change just one Injector? He could apparently see that one wasnt spraying correctly? Now after more research maybe this guy just wanted to make some cash!
Anyway.. After it was "fixed" i drove it for just a few days before the emissions light and also this time the check engine warning light came on.
The problem is now and always has been with the PDF, or to say the bus blows white smoke. I can be driving along to then feel the motor maybe misses a beat. I look in the mirror and extreme white smoke is pouring out the back?
I understand this idea that the motor itself is not really designed for short journeys (stop/start) and i have read that maybe after around 200kms the motor needs to get a good long run to get it hot enough to burn the bild up inside the partical filter.
I have had this PDF "professionally" cleaned twice. After the last time i drove the bus just 40kms before i felt the bus and once again saw the dreaded white smoke.
I have changed all 5 Injectors and also the AGR (exhaust gas recirculation valve?). A new temperature sensor and i believe another sensor as well. Forgive me as i guess its clear that i am not a proffessional.
Fluid levels dont seem to change much.. the oil looks good! ..black but good!
Thanks to anyone that has spent the time to read about my dilemma and i sincerely welcome any feedback someone may have.
Phil .S
Phil .S
