F
feruiz
Hi! @aeicalifornia, thnak you very much for your valuable feedback which I have not taken into account. You're right, T6 accepts !7 rims with 215 and 235 tyres and your proposal sounds pretty good! setting 235 (which fills better the arc) and downgrade the pressure to 3.0.I don't fancy the Valdivia for exactly the same reason as @JuanVecino2023 above.
I would go with Woodstock, but if you get a chance to change the tyres on 235/55R17, don't hesitate, as the comfort will significantly improve merely on the fact that that air pressure to run will be 3.0 atm. instead of 3.8 atm. on the narrower 215/60R17.
and the fuel consumption pretty similar.
Nice balanced option!!!
Thank you
BR's
Fernando
