KGCali
Retired and still young at heart!
In my T5.1 with Climatronic Aircon my wife always complained the heating on the passenger side was cold unless on Max or Auto turned off, especially on her feet whilst mine was fine. I looked into this a while back but then forgot all about it until I purchased an OBD11 Pro diagnostic tool during lockdown to have a play with. Whilst scanning the Aircon system I noticed that the temperature on the footwell vent sensors never moved, one fixed at 58C and the other at 87C whilst the front vent sensors worked fine.
I had a search of YouTube and found a useful video on how this type of sensor worked and then found the California part number 4B0820539 and purchased two used ones from eBay for £2.10 each, a bargain. Tested the replacement ones with a multimeter and haidryer and all worked fine!
Found another useful YouTube video on fitting a T5 carpet which details how to remove the trim under the gearstick which gave access to the driver's side temperature sensor and just a few clips and screws to remove the passenger side lower trim, see YouTube heater resistor video, to access the passenger side temperature sensor.
About 30 minutes to remove both sides, 5 minutes to replace the sensors and the same again to refit the panels using a Torx T20 bit.
Plugged in the OBD11 Pro and started the engine to warm up and now both footwell vent temperature sensors are working fine and warm (or cold as selected) air on both sides!
