You still get the discount. You will get you membership cost back with the first order probably.I’ll certainly join the club but my plan is to place an order and collect.
I find this water filler cap very handy but you do need the appropriate hosepipe connector.Pick up of our new Ocean confirmed for early in the New Year and, as recommended from an earlier post, we plan to stop at Campervan Bits on the way back home to Scotland. I know that there are plenty of threads on essential accessories, but grateful for views on the items I plan to buy at Campervan Bits that may not be quite as easy to see and purchase elsewhere. Items I’m thinking of buying are:
- Comfortz windscreen cover
- Spare wheel lock
- Levelling ramps - maybe not essential?
- Water filler hose - suggested length?
- Hook up cable - suggested length again and need for adapter (trip to France planned in spring)
- Porta Potty 335 - I know I could buy locally but probably worth buying straight away
- Carpet for living area - is it worth buying the Brandrupp fitted one for £189?
- Not planning on buying seat covers as no children and expect to put a throw on back seats - thoughts?
Depending on my wife’s liking I’ll probably pick up a Ridge Monkey XL along with folding kettle, pots and pans etc but I’m know I can buy these items locally from GoOutdoors etc and once I’ve worked out what we really need. So happy to trawl through existing threads.
Any thoughts or advice grateful received - just need to get Christmas out the way then we can have some proper fun!
electrical fires can be, yesCatastrophic?
Is a coiled cable more likely to cause an electrical fire?electrical fires can be, yes
Under high load it can get warm/hot - if it’s coiled that heat can’t dissipate and in theory could get hot enough to melt the insulation and short out.Is a coiled cable more likely to cause an electrical fire?
The heat produced is proportional to the square of the current and length of the cable. H = k.I^2.R The rating of the cable is based around typical ambient air circulating around it.Is a coiled cable more likely to cause an electrical fire?
Mines about 24 inches long with a funnel at one end. it takes up little space and we fill it with our five litre water bottle.any suggestions for minimum length of water hose?
A good illustration of coiled vs uncoiled safe current load can be seen on the label on the side of most normal 3-pin reel extension leads; the one I’m looking at now when unwound the full 13A can be sent through it but when coiled it is rated to just 3A.The heat produced is proportional to the square of the current and length of the cable. H = k.I^2.R The rating of the cable is based around typical ambient air circulating around it.
Oddly, though often cited, the inductance produced by placing it in a coil is negligible.
If (as I do) you operate at less than 50% rated current you'll probably notice no temperature increase. Otherwise unwinding the cable is a good idea.
I have my 25m cable on a reel. I presume that counts as coiled. I don’t remember reading anything about reduced performance or safety from unwinding it, perhaps because they design it to be operated at <50% rated currentThe heat produced is proportional to the square of the current and length of the cable. H = k.I^2.R The rating of the cable is based around typical ambient air circulating around it.
lunch at Moonbeams music festival this summer,.Note the sun screen cover.A kettle or small electric fan will cause the cable insulation to melt if coiled up! I know!The heat produced is proportional to the square of the current and length of the cable. H = k.I^2.R The rating of the cable is based around typical ambient air circulating around it.
Our experience:-Pick up of our new Ocean confirmed for early in the New Year and, as recommended from an earlier post, we plan to stop at Campervan Bits on the way back home to Scotland. I know that there are plenty of threads on essential accessories, but grateful for views on the items I plan to buy at Campervan Bits that may not be quite as easy to see and purchase elsewhere. Items I’m thinking of buying are:
- Spare wheel lock
Kettle typically draws around 2500W. Assuming you mean "small electric fan heater" the power consumption at max is similar. Both appliances around 80+% of typical cable's rating in free air.A kettle or small electric fan will cause the cable insulation to melt if coiled up! I know!
Thanks, helpful,adviceOur experience:-
Comfortz windscreen cover - we’ve got an internal one Isolite - stays dry.
- Spare wheel lock - we don’t have a spare
- Levelling ramps - maybe not essential? - very essential, and as we camp on uneven pitches we have two sets.
- Water filler hose - suggested length? We have a 20m one for home, and a 7m flat hose for site fill ups (fits nicely on top of Gaz bottle)
- Hook up cable - suggested length again and need for adapter (trip to France planned in spring) - 25m is best. The van comes with a Euro to UK waterproof adaptor. Best also to get a standard UK house socket to iso socket.
- Porta Potty 335 - I know I could buy locally but probably worth buying straight away - yep
- Carpet for living area - is it worth buying the Brandrupp fitted one for £189? - Your choice. We bought 2 mats from Dunelm at £12 each, plus 2 for the boot.
- Not planning on buying seat covers as no children and expect to put a throw on back seats - thoughts? - we don’t have young kids but still bought covers. The seat fabric is stupidly light and the covers protect against spills etc.
Ridge Monkey? - Yes, the best pan we’ve bought is the deep pan with griddle lid. We have an XL toastie pan but don’t use that much. Another great pan is the Cadac Paella pan - we use it on the outdoor stove mostly.
Folding kettle - yes we bought one, though I prefer the Outdoor Revolution whistling kettle.
You’ll also need a 907 Campingaz Cylinder. The shop does them.
Good luck - have fun!
It is silicone not rubber and has no taste at all..we use it 8 years 50 days a year..I can't recommend them. I'll drink anything, but the Mrs doesn't like the taste, presumably from the rubber. We bought a cheap metal kettle with a slim profile that fits the bill nicely.
By all means use cable reels so long as you’re aware of their limitations, and risks.I have my 25m cable on a reel. I presume that counts as coiled. I don’t remember reading anything about reduced performance or safety from unwinding it, perhaps because they design it to be operated at <50% rated current
Yes fair enough. Like I say, I’m happy but the Mrs thinks she can taste it. Even after a year. So we reverted to a metal kettleIt is silicone not rubber and has no taste at all..we use it 8 years 50 days a year..
maybe rinse it before first use ?
Please elaborate - we've just purchased a collapsible kettleDitto. folding kettle can also be dangerous.....
My electric folding kettle can ‘flex’ mid-pour. Needs a finger to steady the base. Fine once you know how, but not the best design …Please elaborate - we've just purchased a collapsible kettle
