T
Tim T
Guest User
Not really storm, I sold my Cali and am not really interested in hanging about, I would have asked for my account to be deleted anyway.Did he just storm out?
I had the same on a Jaguar, it was metal on metal which only made a noise below 10mph. Trusted the dealer to check the pads would make it to the next service but they didn’t. New rear discs and pads and damaged powder coat on the wheel due to hot embedded steel particles, not happy.Just noticed the rear passenger wheel is covered in orange dust after an hour journey yesterday. Not sure that’s good news - only rusted disc ? - or not…?
I’ve seen boat anchors in better state than thatJust took this off my bmw. Noise sounded like a wheel bearing going. The rust had got behind the braking surface causing it delamination. The pads amazingly were fine. It is wise to check out unusual noise from wheels and brakes ASAP. A faint grinding noise won't probably do much harm if its just worn pads
I recently replaced rear disc & pads as picked up as being down to 25% on last service and would need replacing at next service.So what happened to the warning light that must’ve come on about 6months ago?
I would be petrified just jacking it up!This is such an easy fix with basic mechanical knowledge and tools. Takes about Half a day if you take half hourly tea breaks.
Cost £127 for Bosch pads and discs.
And while you are at it replace the ABS sensors at the same time for less than £15.
