stim
I have just spent the night in the van and had problems running the heater. It was working fine while we were having dinner but then at some point in the night it stopped working and would not start again. I think it shut off after seemingly spinning up the fan, but not sure about that because I was half asleep. The van is a 2 year old T6.1 Beach with 75Ah battery.
Here is a summary:
Bit disappointed that after only 2 years my battery cannot handle one night of camping with the heater but I guess that is what happens with AGMs (I am not able to plug it into the mains for 24+ hours to keep it in good shape).
Thanks in advance!
Here is a summary:
- Tried to turn on heating with both control panel and remote using both heat continuously and heat immediately. Always the same result. Heater light would come on and then turn off after a minute or so. Sometimes you would hear it try to start, sometimes not.
- Battery was at around 12.5/12.6v (so nearly full) when we arrived and about 12/12.1v when the problem started. When it did try to start and amps were drawn, the voltage dropped to 11.something.
- The heater would start fine with the engine running and continue to run once the engine turned off.
- My friends with an Ocean next to us had no problems with the heater all night and were also reading the same voltage on the control panel (12v).
Thanks in advance!
