R
Russbathuk123
Hi Betsy
Thanks for upi
Thanks for upi
Thank you for your info. We need to have ours changed, do you have any idea what to ask for? Obviously like for like pop top will be the same. Do you know what’s different with the new one. Our Cali is 3 months old and leakingWater test completed, no rain of worthy mention here today so I reverted to my normal garden hosepipe. Started off very wary with a mist that was quite light, aimed directly at the front of the bellows. Nothing at all after 5 minutes.
Got mega confident and turned the hose on full with a heavy spray pattern, aimed again at the bellows largest area standing just in front of the front bumper (got a bit closer now). A solid 5 minutes longer. I’m now gobsmacked as it’s still bone dry inside. Left it to rest now for 30 minutes (thought the water might wet the canvas and drain down like the old bellows did). Repeated the hose on full for another 5 minutes. It’s still dry. Left it now for 2 hours still nothing at all inside. No weeping dripping or seeping. No glistening. The old bellows failed within 5 minutes previously.
noticeable differences between this bellows and the old one.
canvas doesn’t change colour when being subjected to water
inside the base of the bellows appears to be hermetically sealed rubber. The old wasn't, I think it was cloth.
it’s moderately less tight, but hardly noticeable.
err, it’s dry inside
can’t get to the numbers inside it would damage the bellows.
I will sign off that it’s fine when I’ve had a night of heavy rain but I’m very optimistic now.
the bellows that were replaced were the ones that came on the vehicle when new in September.
Hi BetsyWater test completed, no rain of worthy mention here today so I reverted to my normal garden hosepipe. Started off very wary with a mist that was quite light, aimed directly at the front of the bellows. Nothing at all after 5 minutes.
