Tocosan
Rodent damage - Possibly blown fuses? - My oil lamp started flashing with the message indicating I should go to the workshop. Also I had a Start-Stop Error message (start stop was not working). Booked into SMG Cowfold Monday, where they quickly discovered that the three wires coming out of the oil pressure monitor had beed severed, probably by a rat. This was fixed (£around 160) and all was good. Thursday the oil lamp flashed again. I checked under the van and found that the newly repaired cable had been cut again. I repaired the wires myself and plugged it back in. Using my Carista I tried to reset the alarms. They reset and then returned immediately. Codes I get are 16230, 9453842, 9479189 - SIGNAL WIRE FOR AIR QUALITY SENSOR: OPEN CIRCUIT/SHORT CIRCUIT TO B+, 9481748 - High pressure sensor: open circuit to Ground. Also start stop does not work. I am hoping that the faults are due to a fuse being blown somewhere. Can anyone suggest if the cut cables could have resulted in a blown fuse, and if so which fuse/s should be checked?
