Little owl1963
Recently had situation were was inside living area, an the lights came on when opened slider door .
But would not turn of manually once i was inside ? or dim ??
They did turn off themselves after a delay , but then i could not turn them manually back on ??
Only by the front control panel .
Only the elongated middle light above sink i could turn off or on nothing else .
I must let you no the camping mode was not activated .
Also does it matter to inside lighting if slider is open or closed ??
The control panel was showing 12.3 v at 1 amp
Is the above a fault was bewildered why i could not turn on/off lights or adjust dimness ??
does haveing the door open or closed have any affect on the living area lights ?
