Porta Potti storage…….. buy now!
chockswahay
chockswahay
Kernow
T6.1 Coast 150
Hi team :) Just a quick heads up for anyone with a Porta Potti who has not yet bought one of these………
Now available for £8.40. Bargain!
We have had ours for over a year now. It hides the loo in plain sight and makes a perfect spare seat or foot stool :thumb
Yes, this is a neat & useful bit of kit that hides the unmentionable very nicely.
Is this for a 335? Do you just use the bottom part (upside down) and discard the lid?
If you want to sit on it, the lid gives stability. If not, just invert the box - I often put the lid back on the inverted box so it all lifts off quickly when needed.
Use the box part, upside-down, to cover the loo, and put the lid over what is now the top. Just lift off at night-time - the box part folds up neatly & fits inside the lid. I've ditched the square stiffening panel as it's not necessary if you're using it upside-down. It's stable enough to use as a stool (away from the loo) upside-down with the lid on to keep it square.
I was dumb enough the put the 335 in the box and then put the.lid on. Perfect, I thought......until I needed a waz in the middle of the night. Talk about panic. Could I get the damn thing out of the box? ‍♂️. Took that long, I nearly wet myself
If you put the 335 in the ottoman (turned upside down) and put the lid on, you can remove both the lid and the ottoman by grabbing both and waiting for teh cube to slide out. Gravity will do the work. Takes a few seconds.
