Tap for kitchen sink and water pump
Curious if anyone has the details on the new tap (Model # from Reich)?
We are experiencing the issue with the tap and water pump- when we bought our van in April it was already out of warranty- so we want to replace ourselves to save the ridiculous cost the dealer wants to charge.
Thanks in advance!
I got this one - to replace my ”new” model,
the actual lever was different, so I swapped it often broken one (internal leak)
ive since learnt the internal ceramic cartridge is replaceable… so could have saved some money. It was under warranty, but with fuel costs and time off work it was cheaper for me to just get a new tap.
if you have older style tap, you will have to drill hole bigger where tap fits
the dealers remove entire sink and disconnect gas…
Thanks @AndrewCook680...very helpful!
Just thought I would follow-up with a note that we have completed the tap replacement. We ended up purchasing from amazon.de, as Ebay.uk was adding quite a bit of extra to ship to the EU.
https://www.amazon.de/dp/B01N0EP5IB/?tag=unique0ed-21
We did not remove the sink as mentioned that the dealer would do. We did have to enlarge the hole for the tap, as also mentioned above. The hardest part was the awkward position the person installing (my husband) had to contort himself into. But now we have a working tap with no leaks....we will be putting it to a full test on our next trip in October- hoping this fully resolved the water pump running issue- which based on everything I know it should!
I included some photos of what the old tap looked like when we removed it.
Van Tap.jpgVan Tap 3.jpgVan Tap 2.jpgVan Tap 4.jpgVan Tap 5.jpgVan Tap 6.jpg
Hi All
Due to a problem of continuous operation of the water pump at certain times, VW has diagnosticed that there was a problem with the kitchen tap
As it isn't completely waterproof, the water comes to establish the contact inside which triggers the pump !
The tap was replaced iwarranty (REICH model)
Now, no problem with the water pump
Hi All
My tap was also replaced under warranty...however the replacement tap also has a non water right base which allows water to come in contact with the micro switch causing the pump to run continuously. I have put a switch in the circuit to isolate the tap microswitch from the pump. Once I've isolated the tap I remove the cover...dry the switch with a hair drier ...quick squirt of wd40...and good to go....till next time!
Feeling left out with the tap issue until today. It’s finally failed after 5 years and it’s not the usual water or welded contacts. The actual spring return has failed. It’s a crazily stupid design for a tap switch and no wonder the VW were replacing them. Unfortunately my van is out of warranty and I need a replacement. Does anyone know the part number?
Have it now courtesy of the fb group. 7C4 068 165A
Going to set you back £63.60p plus vat
We’re in Alsace and just got the problem with the kitchen tap and the constant water pump.
Are there any German GC owners who can recommend a dealer in northern Germany who can fix this problem? We are from Denmark so anything in the North of Germany would be great. The Danish dealers have no idea as I understand there are only so 2 GC in Denmark.
Appreciate your help.
I've also had the new tap fitted on our GC 600s. AFAIK the tap is now an official TPI (Technical Bulletin) and can be replaced free of charge under warranty. It looks and feels much better. Time will tell of course but VW wouldn't have taken so long to address this without making sure that this new tap is up to standard...or at least I sincerely hope so!
Hi Soton Campers,I recently had my tap replaced with the new model as shown in your picture. My old tap only moved up and down, but the new one also moves side to side. Is this side-to-side movement a new feature of the model, or could it be that the VW technician didn’t tighten the tap securely during installation? Thanks
This is common in many motorhomes and caravans, the best solution is to insert a relay between the tap(s) and the pump, this will reduce the current load on the micro switch contacts making them last a lot longer. The relay has contacts rated far higher to switch the pump on and off,
@secret lemonade drinker - I think the microswitches (sink+bathroom) are not directly connected to the pump - if you are moving the pump is disabled despite the tap turning on/off.
When my pump goes - I am planning to replace with a pressure pump rather than a direct driven one.
I recently had my tap replaced with the new model. My old tap only moved up and down, but the new one also moves side to side. Is this side-to-side movement a new feature of the model, or could it be that the VW technician didn’t tighten the tap securely during installation? Thanks
If its a reich comet tap it is supposed to rotate about the base, when it freezes this is the bit that deforms!
Problem with tap contacts appears endless. Suggest the real solution is to use a relay, in the area above the water tank, this switches the pump current and the tap micro switch just needs to switch a tiny control current.
Another mis step in design by vw
GS O’brino - Is the whole tap moving, or just the top?
The original tap was just moving up and down, but the new one have a side to side movement at the base, like in the pictures. This is a new feature? Or it is loose?
We had the old tap replaced in March 2025 and it worked fine until last week. Then the pump started running just as we went to bed. The only solution was to remove the fuse. In the morning it seemed fine so I’m guessing it’s the same wet micro switch problem. Anyone else experiencing this with the new issue tap and how did you fix the problem? We’re of to Italy next week and I don’t fancy doing DIY in 30+ deg.
Thanks.
Water in micro switch....an eternal.problem!. I eventually installed a toggle switch in the micro switch circuit to the pump. Allows me to switch off pump and do the necessary to dry the points out without struggling around in the virtually inaccessible fuse cupboard. Good luck
Do you have a photo of the isolation switch? My new tap is driving me crazy. Emptying the boot with all our crap to turn off the main switch is a pain in the ****
I always open the sink cover as soon as I stop the van to improve ventilation and avoid leaving any wet sponges or cloths inside. Steam from the sink area rises and enters the tap’s micro-switch, which leads to corrosion or failure over time.
