Perfectos
Very easy to fit :Hi all - had been admiring photos of the vinyl table tops and now I know - Pixers looks amazing!! Couple of questions- which size do you get for the table tops - or do you get a ‘personalized size’ and then cut to size? and are they easy to get off if you want to change or do they leave a residue? Thanks
degrease the table properly paying attention to the edges, repeat
let it dry fully (Isopropyl Alcohol etc).
align the sticker on the table and tape in desired position at one end and the sides to hold it in position (masking tape etc)
Starting from one end : peel part of the backing sheet off (just enough to get started, leave the backing sheet attached.
check the alignment is 100% (peel it off carefully if you need to and realign as necessary)
using a credit card or vinyl squeegee apply the sticker removing all air bubbles as you go.
use the Squeegee to press the sticker into the edges
gradually peel back to backing as you work the squeegee from side to side, removing all air bubbles as you go.
when the sticker is fully attached & worked into the table edge profile, take a sharp blade and carefully cut away the excess (using the table edge as a guide) it helps to cut into the edge at an angle (not vertical)
final press / smooth of the edges
if you have any air bubbles (which you shouldn’t if you have fitted it correctl, use a pin to pop the bubble then squeegee to flatten
removal is as simple as peeling it off
edit : for the table in the door, I ordered 90cm long x 52cm wide (Do your own check measure based on the design you choose and the orientation of that design on the table )
