			I've had Lazer Elites fitted to the front, which needed a canbus installed as well, so with the additional reversing lights, it will probably need a canbus to run off the existing revising led lights.Because the 6.1 Cali uses LEDs, it's not quite as simple as it would have been with traditional filament light clusters. Have you tried turning on the rear fog lights? These can throw a fair bit of extra light rearwards. The other thing is the circumstances; do you have a dark driveway or something you're trying to reverse into, or is it for arriving at campsites in the dark? If the former, you could get a solar PIR light and aim it to give light where you need it.
			It's not hard core off roading that the likes of land rovers etc do, it's getting off tarmac and on to gravel or muddy tracks in woods and forests etcSoft roading …….. what’s that please?
			Why not fit a manually operated additional reversing light operated by a switch fitted in a blank on the dashboard.I've had Lazer Elites fitted to the front, which needed a canbus installed as well, so with the additional reversing lights, it will probably need a canbus to run off the existing revising led lights.
It isn't for home or for campsites, it's for soft roading in the wilds of Scottish and north England forests
			Ah, I see now thank you, I guess thats why you have the 4MotionIt's not hard core off roading that the likes of land rovers etc do, it's getting off tarmac and on to gravel or muddy tracks in woods and forests etc
