Surfboard rack options for T6.1 California
Saw those brackets, looks a good option with the wider bars. Not sure my roof box (halfords with the thule jaw clamps) would fit.
Not sure about that - would have to check clearances to the roof.
Also, some roof boxes have a recess for the roofbars (more aerodynamic) this means the box can be very close to the roof in the center. At the edges there is more clearance.
I guess a slightly deeper mount will be preferable for both the Thule quick snap fixings and the box clearance. I will investigate.
John
John
Yes, you are right. The box does have a recess for the bars, had forgotten about that. Will take a look tomorrow and see how far below the top of the bar it would sit.
John
Will your mounts with with the 711320 127cm bars, or do you need 135cm?
I went for 127cm length bars on my own ultra low mounts. Can fit two surfboards side by side but not SUPs. Had to put one SUP on top of the other. Don't know if a thule top box will fit ok with my home made ultra low mounts (10mm lower than the ones on ebay) can't see why not. IMO 127cm length bars look nicer than the 130cm ones.
I have the standard VW roof bars. Must admit, I would mind something a bit lower. They do stand quite high on the roof.
Just realised why the VW roof bars are at the height they’re…
Place my SUP (11') upside down on low roof rails with no overhang at rear only at the front of van. So no issue opening the Van's tailgate
Hi, my mounts will fit the 127 bars. The roof tracks on the California are 121 cm apart, so that leaves enough for the brackets to function, and the bars will overhang the tracks approx. 30mm each side.
John
John
Can't seem to send you a message to order a set!
Hi, I can offer a couple of options.
One is a low profile mounting system for Thule roof bars (ref ebay item 174835748912) - I can make different heights if needed. The other is a side loading roofrack which is a different animal completely. It will be ideal for multiple SUP boards with the right brackets, but I don't think it will work with the Thule SUP taxi very well and this would need to mount to the T-slot instead of the securing straps.
Message me if you would like any further details.
John
Hi JB, think ive just messaged you on eBay. Are you selling on here too?
Yes .... i would prefer to deal direct with forum members - helps to keep the cost down.
I'm in france with limited internet and limited time.
Wil PM you when I get back - probably thursday.
John
any updates on how those are working? was thinking about a set for sand tracks.
yes I have some available - silver or black powdercoated.
email at info@vixxos.com
john
I have some of these super low feet,, they are great.
Just realised, guess there's no chance of fitting a roof box though as the rail will be too low for the fixings?
It will not be an issue provided your roof bars have a slot in the top, just take the rubber out of the slot on the top, and slide the roof box fixings into the slot. You can then trim the rubbers to sit around the fixings (keep the rubber offcuts for when you remove the bars)
You might just need some T-track adaptors to fix the roof box to the rails (although most come with both sets of fittings.)
Got you.
