Why is the multiflex board on a hair trigger!?
F
flymartin
New Forest
T6.1 Beach camper 150
Just back from 3 weeks touring and the van has been splendid. But why oh why is the handle for folding the multiflex board so sensitive? Every time I’m loading up the space under the board if I so much as touch the handle (or just hit one of the folding supports in either side) it triggers the board to fold down.. with the mattress and all sorts of other stuff on top of it, I have to unload a little, reach in from above, and reset the the MFB. So much pointless effort!
Is there a reason why it has to be so sensitive? And has anyone found or invented a lock-out feature to stop it folding unwantedly?
Another newby question froKm me - how do you take the multifex board out. What is the technique. I tried and gave up
I feel your pain. Used to happen to me all the time. I ended up cutting a couple of lengths of dowel and cable-tieing them to the folding hinges to stop it happening. Not the most hi-tech solution but it works and can be easily removed if I ever need to fold the board (which I have never yet needed to do in 7 years of ownership!)
Just watch the loaded height under the release handle; plastic storage boxes will help as provided you don’t load over the lip of the box,
It won’t interfere with the MFB.
Good idea - thanks - will give that a try unless anyone comes up with an even better one..
Just watch the loaded height under the release handle; plastic storage boxes will help.
Thanks, I do have a couple of euro boxes that fit perfectly across the space between the rear bench and the MFB. But there’s 10-12 cm of clearance above them and so I slide things on top of them, and those things trigger the MFB fold.
I feel VW is penalising me for failing to maintain Teutonic minimalism and Ordnung in my boot space!
I’ve done this a few times (3 seat bench Beach) and it is a bit awkward. I think last time, I dropped the bench seat backrest fully forwards; unfastened the multiflex; tilted the multiflex forwards and rolled it up and onto the bench seat; slid the bench seat forward. Now the multiflex is upside down, on top of the bench seat (which is in in ‘table mode’) and ready to slide lengthways through the sliding door.
As you carry it up the driveway and into the house, you can enjoy the various perils of unexpected sudden flap folding, trapped fingers and damaging your doorframe with the rearmost metal multiflex leg.
I’ve never done it but I did stumble across this video which seems helpful:
I previously used this method, but found it a bit tricky to do alone, without banging the van trims and windows, hence my 'controlled rollover method' above.
Obviously if I'm in a hurry (for a divorce), I'll ask Mrs Wease pop out and help with this method in future!
To make removal of the multiflex board easier, move the seat as far forward as possible, undo the base frame fixings fully, lift the MFB up slightly so the fixings come out of the channel, now lift the whole MFB up, to clear the internal side trim and turn through 90 degrees. (Helps to have an assistant due to the weight
“Assistant” they are like gold dust, as soon as you ask for help the tumbleweed rolls by.
It’s the same when the additional 6 & 7th seats need fitting / removal !
