CaliforniaSeb
Hi, has anyone seen anything like this? I assume that the leisure battery drain should show 0A when not in use. The control panel constantly shows 1A being used. I have carefully checked that nothing is on. Including when it is dark. I decided to park up the van and leave it for 7 days. Carefully checking each day to make sure I wasn't actually draining my batteries. Seven days later the reading is exactly the same, 80% charge.I would have expected the batteries to be toast after seven days of 1A drain.
The panel shows the battery charging on hook up or whilst driving. It correctly displays 100% charge and 13V. It shows the battery usage go up if i put the fridge on and play around with the fridge power setting. So it appears to be talking to the batteries.
