T4 wesfalia pop top trim glue which glue to use ?
qyouquestion
qyouquestion
Qyouquestion
Europe
T4 PopTop
Hello can anyone help I’m looking for asdvice on what glue to use on the trim on the pop top roof which glues to the painted fiberglass pop top
Its the top plastic type black trim around the edge of the top bit of roof that rests against the body of the vehicle which is coming away
The trim is in good order so does not need replacing just glued back onto the fiberglass roof
Any help would be appreciated
Thank you
Thank you sidepod just to be sure is this the right glue for this black skirting
I’m not altogether sure it’s glued on at all, just a push fit? If it doesn’t stay put then yes, a bead of Sikaflex will do.
Obvs it’ll need to be removed and cleaned of all the crap that builds up it there.
Thank you Sidepod
