aidanic
Hi there,
We have a 1995 VW T4 California with the Westfalia original build-out and the Westfalia Electrolux RC 1140 fridge. It works mostly. We're doing a longer road trip soon and I want to keep some medication in the fridge while we're on the road.
I want to confirm the performance - if it is what I should expect - and if there's anything I can do to improve the measured performance.
On the control panel test mode, it draws 6.5A, more than the suggested 4.5A from various sources. (Hold down the 4 keys and scroll down to the snowflake).
I've had a temperature monitor in the fridge for the last few days. The van has been in the garage with a nominal 20C external temperature, out of direct sunlight.
Above is the run overnight in the garage - the control panel is set to +2C. The top of those peaks are 9.2C and the bottom are about 4.6C. The cooling cycle has a 15 minute duration, with the warming cycle running over 30 minutes before the compressor kicks in. A total of 45 minutes from "peak to peak". For this test, there is nothing in the fridge except the temperature sensor. And the lid is closed. The 12V charger is plugged into the mains - so no leisure battery issues.
I put 4L of ambient temperature water in plastic bottles in the fridge and it took ~15 hours for the curve to settle down again.
With the 4L water and the sensor, the "peak to peak" period remains at 45 minutes.
What are my options here?
Should I get a new sensor (~€55 from coolandshop.de) and will it do anything?
Can I put additional rockwool or other insulation around the fridge - especially between the fridge and the exterior body panel?
Is there enough "coolant in the pipes"?
Or is it working as expected for a 28 year old fridge - if it ain't broke, don't fix it?
Many thanks in advance for your collective wisdom.
Aidan
Aidan
