chockswahay
So I have been looking into the possibility of filling my own 907’s at home. As it happens the subject was discussed at length on a different thread I started about Propane.
If this helps anyone who wishes to refill their own 907’s this is what I have done.
I bought an empty (well 2Kgs left) 15Kg Calor Butane cylinder for £10 off Gumtree
From BES I ordered a clip on adaptor for the 15Kg cylinder (part no 16642) and a pigtail (part no 12648) to connect it to the GOK valve on the 907 (supplied by VW).
I placed the 15 kg cylinder upside down a little higher than the 907, opened the valve on the 15, opened the valve on the 907…. and liquid transfer started. To increase the pressure differential between the two I cooled the small one and poured a kettle of boiling water on the big one.
I weighed the 907 and used the difference between tare and total full to calculate when the 907 was full. As it happens due to not being able to vent any gas during the process the liquid transfer slowed down to a snails pace at a total weight of 6.1 Kg so it is 0.5 under maximum. This I am happy with.
Now I know that anyone reading this may have their own views and opinions regarding the safety and integrity and I am certainly not suggesting that anyone else does the same. However it is a matter of competence and common sense and should only be carried out in a well ventilated area away from people, superstructures and any potential source of ignition,
(Disclaimer: I was a professional hot air balloon pilot for many years and this procedure is fairly standard when pressure fuel pumps and bulk gas tanks are not at hand. We used to get through many 100s of litres a week of Propane)
