Does anyone know the part number for the new bellows as seen in the video below?
Mr B
UK
Updated VW California Roof Canvas​
The ones I was going to buy are Part number: 7E7875059KIU7 - but I'm unsure if the new canvas has an updated part number.
Thanks if you do know and can reply!!
EDITED:
I have found 2 more part numbers:
7LA8750597MH - (Charcoal and Cream - Dual material - zip down front for electric roofs) - which has superseded the number below.
7E7875059KIU7 - (Charcoal Single Material - zip down front for electric roofs)
I've confirmed this with SMG Tonbridge now.
Those part numbers are correct.
I have also found out that there is another part number that is for vans being built next month which is the same as the above number but with a 'C' in it.
This is not available for retail yet: 7LA875059C7MH - I wonder if this is to fix the seam issues some people have experienced.
You may want to check out some of the threads on leaking bellows; the new new ones (light inside, dark outside) seem to have some issues!
Ok thank you - I will read about them!
Yes - I just read that - and now unsure if I want those bellows - might stick with the original canvas with opening front!
However I do normally cover the pop top if there is a chance of rain - and we have successfully camped in wild weather with the cover and never got wet - so if use that on the new bellows it shouldn't really affect me in bad weather.
But... do I really want to have a possible leaky canvas - probably not - although that new material looks really nice on the inside as its so much lighter.
