calibusje
- Messages
- 1,561
- Vehicle
- T6.1 Coast 150
Very well editedHere's what the manual has to say on the subject:
Maximum battery charge
The 230-V supply with the battery charger charges the additional battery from the outside 230-volt electrical feed. The current charge level of the additional battery is displayed in the start screen Central control panel start screen.
In order to completely charge the additional battery when driving independently of the vehicle functions, you can activate the maximum battery charge function.
The function increases the idling speed of the engine. The fuel consumption may increase as a result.
Switching maximum battery charge function on and off
The maximum battery charge can only be activated when the engine is switched on.
Switch on the engine and the central control panel.
Tap the Max. charge menu.
The Max. charge menu is highlighted in yellow and the symbol appears in the header.
The function switches itself off automatically when the additional battery is fully charged.
Tap the Max. charge menu again to switch it off manually.
Or: Switch off the engine.
The Max. charge menu is highlighted in grey and the symbol disappears from the header.
If the function is switched off manually while the engine is idling, the engine speed will be reduced again only after you briefly press the accelerator.
To me, VW's intent in the second paragraph is along the lines of "If you want to fully charge your battery without EHU"
It certainly doesn't read as an operational limitation and I have some experience in extracting operational limitations from manuals.
Andy's suggestion to calm down is likely a good one. Everyone here will have noticed your climate stance and respect that.
