R
RichardCC
Hi all
I have water leaking from the outlet of the fresh water tank when the valve is fully closed. The rubber seal is not doing its job and my tank is drained within a couple of hours. Have tried retightening the valve lever next to the tank, but no joy.
I have read through the many threads on this problem, but I cannot see any actual information on how to get to the rubber seal itself to check its condition. If I remove the protective pan underneath the van, can someone tell me if this gives me access to the outlet seal? Otherwise to repair this properly, I guess I will need to remove the built in units to get to the tank itself.
Thanks for any advice. And if anyone can recommend a specialist in the west Dorset area, this would be very good to know.
