T6.1 Ocean grey water
  • Thread starter CaptainCalifornia
  • Start date
CaptainCalifornia
CaptainCalifornia
London
T6.1 Ocean 204 4 motion
Hi
My waste water graphic on high level centre screen always shows yellow at the bottom Even when completely empty. Does anyone know if this Is normal or do I have an issue with faulty indicator or tank float? It reads as if I have a minimal amount of grey water in tank all the time. Many thanks
Mines the same, even when I’ve driven with the valve open for a complete empty
Hi
Normal.
Thanks all, after spending a small fortune nice to know working as it should
Hi
Yep 100% normal. When full, the graphic changes to show full, and you’ll get a message to tell you to empty it. If you don’t it just overflows. When cleaning the fresh water tank we run sterilised water into the grey tank until full, which does two things, it gives the tank a good clean, and it tests the high level sensor that normally never sees liquid.
Thanks mate great info
JuanVecino2023
JuanVecino2023
JuanVecino2023
10K
Davide Fiorio
D
Peter Horvath
17K
Aberdeenshire
