babble
This sounds ideal! Thanks for this.IMO a good option for adding to an existing installation is the Sterling Battery to Battery Maintainer. It's fairly cheap and doesn't require wires to be run between the batteries, (it' can be wired across the split charge relay under the passenger seat. Not designed to re-charge a flat battery.
Sterling Battery-Battery Maintainer 12V-12V, 3A
The Sterling B2B Maintainer diverts a small current from a charging source to a second battery, preventing self-discharge & extending battery service life.www.12voltplanet.co.uk
