Roof drains
JohnCalifornia
JohnCalifornia
North Yorkshire
T6 Ocean 199
Hi are there 2 drains for the roof at the front of the Cali? I’ve tried pouring water down both sides. The drivers side gurgles and water comes out of the bottom of the van. The passenger side does nothing and the water pools. Also I have long black covers over the drains. I have been looking at previous posts on this and the photos actually show the drain hole. My drain holes are behind this long black cover. Does this need removing to clean them out?
Thanks for any replies
Yes, it just pulls off. Don't poke anything down the drain.
Once the cover is off using a 100ml syringe with a short length of pipe or use just a straw to blow some warm water down the drain holes until a it runs free.
Ok I’ll do it again tomorrow, weather pending obviously. I have got a syringe of any type but the missus mentioned a turkey baster may do the same job. ….Good idea me thinks
You may not get enough pressure with the baster, worth purchasing a 100ml syringe and clean the drains every time you wash the Cali :)
cobee Plastic Syringe with Tube 100 ml Large Plastic Syringe with 130cm Hose Tube Large Plastic Measuring Syringe for Feeding Watering Nutrient Measuring Scientific Labs Glue Applicator Experiments
I’ve read putting the end of a tyrap down it just to dislodge any debris. Is this still not a good idea?
I found a portable garden sprayer (Hozelock or similar) did the job just fine :thumb
There is a right angle bend just inside the drain hole where the down tube connects so it's advised not to poke anything down the drain hole in case it dislodges the down tube which would be a major issue to repair.
Well I don’t want to risk doing any damage so or doing that then. I’ve ordered the syringe thing so should be with me tomorrow
Ok so I have taken the black covers off but still no obvious hole . I have some dodgy looking pipe silicone thing going in. Do I unplug this to access the drain hole. Pic attached
Yep found them and both gurgling like they should now. The passenger side was definitely blocked but all sorted with my new syringe so all all good. Checked back ones too and they are clear too
I have just bought this, arrived yesterday, filled it with a strong mix of water and washing up detergent. Seems to work well on roof drains and the side sliding windows - although because it not pumping oil it may fail in time (and you need to get the knack of the pump before inserting into the drains holes):
Just ordered. TY, Db.
Yup JohnCalifornia ..the long black covers just pull off without too much effort to expose the small drain holes.
A bowl of warm slightly soapy water and this excellent bit of kit recommended by another member earlier in the thread did the trick nicely for me:
You might need to use the syringe to squirt a little water in the area that pools to move away any debris and expose the hole that may be blocked. The tubing fits just inside the aperture which is enough so don’t be tempted to shove it in too far as that might dislodge something inside which might be expensive to repair.
Gently does it with a steady gentle delivery is recommended rather than a strong jet.
Cheers
Taff
Cheers
Taff
Hi - would you or someone else be able to show me where the holes are by the front wheels and are there covers to remove? A photo would be fantastic- thanks. I have a T6.1 Ocean. I can locate the front roof drains but can’t see where the channels end. Thanks in anticipation.
I am also interested in this.
There is a black metal cover on both sides under the bonnet.
I took them out by releasing the 2 Tx30 screws. Then I cut open the water drains.
This is one side, it's the same at the other side.
Clean them out from these grommets upwards. The sediment runs down the tube and fills up here. Don’t cut the grommets.
When the drains are clear, pour a pint of water in the top and you’ll see a strong straight jet of water emit from the grommets.
Just cleared ours out using kit for unblocking the drain hole at the back of a fridge. The pipe from the syringe was slightly too large to create enough pressure, but a bendy drinking straw was perfect for getting in the hole.
Thanks for the advice all.
Great thread, thank you all for advice. I ordered the device from above mentioned by "victorgeorge" from eBay, however its going to be 3 weeks delivery, so I took the dodgy decision to use a bendy straw as mentioned above and sucked out the grime. straw was clear so I could see the debris before it got to me, not recommended but I was desperate to clear the drains before having my new roof canvas fitted on Tuesday!
I'm still alive and the drains are gurgling nicely
Just found this thread too late.
Roof all clogged with sand after attempting NC500 in a storm.
Was using an ear syringe bulb effectively on the other drains but driver front completely blocked…
Poked something down the hole so may have dislodged the pipe as now getting water in the footwell.
Has anyone got to this pipe taking off the pillar trim? How easy is it to do?
Thanks for the advice.
Think you'll need to take the roof lining out or lower it if you've dislodged the pipe at the bend :(. May be worth removing the A pillar first and seeing if the pipe is loose or watch where the water leaks from as there is another joint further down that can just about be reached from the top the the foot well.
Thanks. Coming from under dash so presume dislodged pipe at top.
Is there a starting point for removing the A pillar or just start prising off?
Have a search on the forums for A pillar removal, loads of posts, info and photos. Good luck.
slowcoach65
Paul1
Paul1
Matthew Mills
8K
fraser500
fraser500
Buddy
19K
TripleBee
TripleBee
