Roof light needed
JohnCalifornia
JohnCalifornia
North Yorkshire
T6 Ocean 199
Hi, so today I noticed the light above the sliding door doesn’t work. I took it out and it looks like a dry solder joint. I tried to re solder but still didn’t work. I removed another light from the other side and plugged it in and it worked 1FB44CCC-A949-4D56-BFD7-6126D3319FDD.jpeg so I know the wiring is ok. The part number is on the picture attached. I’ve tried EBay and google but no joy. I will obviously order from a dealership if need be.
Thanks for any replies
Hi, so today I noticed the light above the sliding door doesn’t work. I took it out and it looks like a dry solder joint. I tried to re solder but still didn’t work. I removed another light from the other side and plugged it in and it worked View attachment 107625 so I know the wiring is ok. The part number is on the picture attached. I’ve tried EBay and google but no joy. I will obviously order from a dealership if need be.
John, https://www.lllparts.co.uk/ is a good source for all things VW.
Sent from my Pixel 6 Pro using Tapatalk
