T6.1 Wiring diagram (batteries)
L
Leopold_Stuff
Poland
T6.1 Beach 199
Has anyone have the wiring diagram like the one below but for the T6.1 2021 or can confirm that since then there where no changes? Thanks!
That diagram looks correct. S339 is, I think, 100A on the latest models.
The diagram is missing some devices eg the three battery sensors. There is a more detailed diagram of the camping equipment electrical in the resources section.
Thanks. Unfortunately I don't have the access to those documents in recourses section. "No permission to download".
You can get 'em for a fee either here or from VW's Erwin.
You need to be a VIP to download
Yes I'm talking about the download link in the vip section, but would be very interested if there is a T6.1 schematic available.
I disagree, it shows 240v inverter on the seat & USB sockets by the sink both of which are T6.1 features and not on T6
I do love a diagram, but all I see is boxes and numbers *shrugs* Used to do electrics but thats got me baffled :talktothehand
@yossarian Any idea where the shunt location is in the T6.1 2 batt ocean model?
On the 6.1 the shunt is replaced by J934 and J1116.
J934 -Battery monitor control unit 2, on earth cable battery clamp
Thanks so much, I just found out that now there is a shunt per battery and they are built in on the neg terminal on each batt. They send data to control panel wirelessly and control panel do the sum.
J934 and J1116 communicate with J608 (the special CU) over a lin bus.
Does the starter battery also have its own shunt?
Otherwise I'll install my Intact battery guard from our T5 when we have our T6.1 Ocean next week.
That’s because the key to the numbers is missing from that screen shot. Ex below.
If this is about connecting a charger then make sure to do a voltdrop check between the battery post and wherever you connect the crocs to. You may find you’ve left half a volt on the table.
