Under hob sliding door catch
MauriceG’Rage
Norfolk
T6.1 Ocean 204 4 motion
Working through the minor problems in our recently acquired 2021 Ocean . . I've replaced the catch that's part of the left hand sliding cupboard door under the hob - I gather this is a common failure where the hook part snaps off; only to find that the other part of the catch, the part that's part of the side wall of the cupbard, is also broken. I've managed to identify it as a "closing element" and I've got one on order - isn't VW plastic expensive? - but can't see how to remove and fit the offending part. I wouldn't think think this is a common failure, but is there anyone who can help?
Hi
Ive just had my catch snap off did you order the new one from VW?
FYI I had a new one supplied by VW under warranty. However I repaired the broken one with Araldite and it’s still holding up. (Possibly stronger now?) Keeping the new one as a spare.
Tricky, does it clip in somehow ? You will see when you get the part, no 17, if there are screw holes. I think the fridge will have to come out to get behind if it does.
Thanks for that we have the left hand catch broken. I have ordered and will take a look when it arrives.
If it’s the part that screws onto the door, that’s only 3 small Allen screws, won’t take 5 minutes to change.
3 torx head screws reached from inside the cupboard. When fitting the new one I found it easiest to partially fit the screws, then position the catch (it lines itself up) and then screw tight. Easy job. Certainly no need to remove the fridge!!
No, it’s not that bit, that’s part 10, part 17 is the bit with the semi- circular hole that part 10 goes into, on the side of the cupboard.
They are very badly designed. We’ve got through two of them and stopped.
Instead we have put a little stopper in the bottom rail of the left door. This stops the right door from moving too far left which makes it tricky to slide back.
BlueTack in the bottom guide makes for a quick cheap remedy.
Has anybody fitted a replacement part 17 as per this thread? I think I have the same issue. Hoping it doesnt require fridge out!
I haven’t used the cupboards yet & noticed the other day that the left hand sliding door refuses to stay closed. I close it and then I find it ajar later. Is this the problem you’re describing? It appears that part 10 is still complete but I have my doubts about part 17… I can just feel something like broken tooth… Does this mean something is broken despite not having even used it?
ours broke last month
It’s very unlikely 17 is broken. More like 10 which is a simple fix and the parts 15 quid online. Replaced mine last week in 5 mins.
Hi if it's the part that is on the wall of the cupboard then the only way to change the one on the left is to remove the fridge. I replaced ours when I got the van and with the fridge out its very easy.....
See my fix posted Aug 13th 2023, which is pretty ‘clean’ and avoids pulling the entire unit apart to get access:
Same solution as Johnny Rocket but used strong double sided adhesive tape.
Morning Trojax. Just read your post with interest. How easy is it to get the fridge out? I have a need to replace the Fridge door catch (Actually VW will replace under warranty) and I am a little nervous about them doing such a job. No date fixed yet.
Hi Jabber
Hi Jabber
well to get the fridge out is tricky but as long as the wardrobe is protected should not pose any issues...but it is tight.
Regards Terry
