Garga solar
jose vicente alamo
Las Palmas de Gran Canaria, Las Palmas
Grand California 600
Bnas noches.
tengo la siguiente pregunta mientras esta el motor en marcha y cargando la bateria con el alternador.
también se carga con la energía solar a la misma vez?
Bnas noches.
That's a difficult one, technically yes the solar charging will still be active, but the solar charger will have one charging profile and the alternator another. Whichever is set to the highest voltage at any point, will win and the other will give up. In reality this means the solar will likely only do anything if the alternator is a "smart" alternator and has shut itself off because it thinks the battery is full enough. Then the solar might kick in again and do something.
jose vicente alamo
markicp
jose vicente alamo
jose vicente alamo
babble
babble
