Which fuse type in a T6?
Emilk
Emilk
Denmark
T6 Coast 102
Good evening all,
Looking to buy a hardwire kit for my Viofo A129 Duo dash-cam, but unsure which fuse type I should pick.
On the website they're showing ATC, ATS, Micro2 and Mini as the options.
Any ideas on which one to pick here when buying the hardwire kit for a T6 from 2017?
Thanks in advance!
If I were you, I would remove the fuse I plan to connect to, and I would know.
I'll do that! Since it's been a while since I had to replace any fuses, I've probably forgotten - are the fuses used a combination of multiple of the fuse types above? If so, I realise that my question is .. silly. :D
I'll definitely follow your advice and update this post with what I ended up doing (for posterity)!
There are several types of fuses (2?) in the box. Here is an identification of these made by @Loz . Thanks to him.Fuse-Card.png
California Dreamin
34K
David Ashcroft
David Ashcroft
K
Resfeber
R
