deltheblue
Having read through alot of the threads on similar issues I have to ask for advice on this
My roof wouldnt go up fully,i did check for faults and cleared the 1000 fault
My visual check on the rams has shown one of them does appear to have some sort of leak or residue under the cover
When the roof did go up it was a little noisy from the pump
I'm guessing either the fluid is low due to the leak and I need to replace the arms and top up the fluid or worse the pump needs replacing
Expert advice on a course of action from here would be great,do I start with replacing the two rams first?
