Blind spot mirrors??
Chris Ratay
Chris Ratay
Overlanding South America w T6.1 Ocean 204, 4M+
Budapest
T6.1 Ocean 204 4 motion
Looking to add little blind spot mirrors to both my side mirrors, like on my moto.
For LHD, is the best location area #1, 2, 3, or 4, and why?
My T6 had this wide angle glass fitted as standard.
A big issue then this is a solution. No heater so gets water globules during rain.
The replacement mirror is good for close in, but how is it for seeing distance, like in a highway?
Distance is OK, close can be a problem as if you try to set it wide the actual mirror housing edge restricts the view. If you look at your photo its the area left of 1 & 4 .
Problem that I previously found with the little stick mirrors was due to how far away they are on your passenger side that it wasn't possible to actually see much at a glance. OK at arms length on your Moto.
I had them on my Defender in position #3 and worked well, but closer proximity than the van.
I more want for drivers side for merging - just to see if something is there
Not used but look like would be a better view than a circular type.
I am not sure of the benefit - wouldn’t fitting them on the mirrors in any of those positions reduce the standard field of view, which in turn would offset any small gains? Tbh I find the van mirrors are the best I have ever used on any vehicle (including bikes), plus you have very effective blind spot warning lights on the T6.1.
